-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Weak spark? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/590832-weak-spark.html)
Kevin (guest) 02-09-2011 11:12 PM
Hi I have low spark on sixth cylinder all other 5 are fine and its not the wire cause I swapped it and same weak spark could my problem be the coil and the engine is a 2.7l 325e
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW E30 3 Series Ignition System Tune-Up
Wayne 962 02-09-2011 11:12 PM
If it were the coil, then it should affect all of your plugs equally. I would suspect it's either a spark plug wire, a cap, or a rotor issue. I would replace each of those one-by-one and see if it fixes the problem.
- Wayne
