Guest
Posts: n/a
Hi I have low spark on sixth cylinder all other 5 are fine and its not the wire cause I swapped it and same weak spark could my problem be the coil and the engine is a 2.7l 325e
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW E30 3 Series Ignition System Tune-Up |
Author of "101 Projects"
If it were the coil, then it should affect all of your plugs equally. I would suspect it's either a spark plug wire, a cap, or a rotor issue. I would replace each of those one-by-one and see if it fixes the problem.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
