69classic (guest)
Guest
Posts: n/a
Hello Wayne,
I have a 1994 BMW 318i and yesterday I had a bad leak and it was coming from what looks like a water manifold under the intake manifold against the head.The plastic piece that the hose hooks to broke completely off.The hose goes up into the intake somewhere.What is that water manifold part called that those 1" or so hoses connect to?
Looks like a hard job to replace
Thanks for your time
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3-Series E36 Cooling System Flush
Old 02-12-2011, 11:08 PM
Author of "101 Projects"
Wayne 962's Avatar
I can't easily tell without a picture - I invite you to post one here in the forums. I'm just taking a wild guess that it's your thermostat housing that broke off. If you check our tech section here on thermostat replacement, you will find complete instructions, and it's not that difficult. Be sure to completely re-bleed the coolant system when you're done!
- Wayne
