kev (guest)
Guest
Posts: n/a
I just changed my brakes and I see the connection for the front brake light sensor but where in the world is the "little" box for the rear sensor?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing BMW Brake Pads
Old 03-13-2011, 02:41 PM
fyi, tip on replacing
it is possible to replace the rear indicator clip-and likely the front-without removing other brake parts.
lift and remove wheel/tire, pull out old clip, and plug in new one. a touch of white lube facilitated easier insert.
the pass. side rear has the brake light indicator.
Old 03-14-2011, 07:25 AM
