Guest
Posts: n/a
I just changed my brakes and I see the connection for the front brake light sensor but where in the world is the "little" box for the rear sensor?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing BMW Brake Pads |
Author of "101 Projects"
The rear sensor "box" and plug should be located near the rear wheel - but only on one side. You may be looking at the opposite side of the car.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
fyi, tip on replacing
it is possible to replace the rear indicator clip-and likely the front-without removing other brake parts.
lift and remove wheel/tire, pull out old clip, and plug in new one. a touch of white lube facilitated easier insert. the pass. side rear has the brake light indicator. |
