-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Erratic running issues... (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/599200-erratic-running-issues.html)
bimmark (guest) 03-25-2011 11:52 PM
I have a 1991 318i m42. Starts and idles great from cold. When I try to start it after its been warmed up it idles irraticly and dies if I dont give it gas. Eventually the idle corrects and it drives just fine with no issues. i have replaced multiple vacuum hoses and cleaned the icv. Tested the icv and get 10 ohms between the two terminals. My icv only has 2 terminals. Is my icv bad? If I unplug it what should happen? Thanks.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW E30 3 Series Idle Speed Troubleshooting
Wayne 962 03-25-2011 11:53 PM
It's difficult to diagnose something like this over the Internet, but it does sound typical of issues you would have if you had a vacuum leak. I would triple-check all the hoses to make sure there are no cracks or leaks.
- Wayne
