bimmark (guest)
Guest
Posts: n/a
I have a 1991 318i m42. Starts and idles great from cold. When I try to start it after its been warmed up it idles irraticly and dies if I dont give it gas. Eventually the idle corrects and it drives just fine with no issues. i have replaced multiple vacuum hoses and cleaned the icv. Tested the icv and get 10 ohms between the two terminals. My icv only has 2 terminals. Is my icv bad? If I unplug it what should happen? Thanks.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW E30 3 Series Idle Speed Troubleshooting
Old 03-25-2011, 11:52 PM
Author of "101 Projects"
Wayne 962's Avatar
It's difficult to diagnose something like this over the Internet, but it does sound typical of issues you would have if you had a vacuum leak. I would triple-check all the hoses to make sure there are no cracks or leaks.
- Wayne
Old 03-25-2011, 11:53 PM
