muly (guest)
Guest
Posts: n/a
I have a 2002 Bmw E46 convertible, the roof opens and closes fine using the button, but there is a small gap on the passenger side windscreen, its as if the hood need to be adjusted 3mm forward on that side, is there any thing i can adjust for this, the hood still loks in place etc
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Convertible Top Adjustment and Repair
Old 04-08-2011, 10:45 PM
Author of "101 Projects"
Wayne 962's Avatar
The problem may be that the window regulator is shot or not properly adjusted. Take a look at the windows article I have and see if you can adjust the amount that the window drops down: http://www.pelicanparts.com/bmw/techarticles/101-Projects-70-Power-Windows/101-Projects-70-Power-Windows.htm
- Wayne
Old 04-09-2011, 04:42 AM
Hi i have taken some pictures as it shows both passenger and drivers side, which may help
Old 04-09-2011, 04:50 AM
