g-string (guest)
Guest
Posts: n/a
Hi does the e36 gear box auto have a oil seal inside the bell housing as i think my box my be losing oil from inside the bell housing
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Automatic Transmission Fluid Change
Old 04-19-2011, 01:26 AM
Jeron's Avatar
The most common gearbox leak is the gear sensor on the side.
In the bell housing you have the engine rear main and the gearbox input shaft seals. You need to determine if it is engine oil or tranny oil, but first determine if the leak is in the bell housing.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 04-20-2011, 12:02 PM
