I installed a Bilstein PPS-9 coil-over suspension in my '97 M3, front camber plates, and Rogue Engineering rear control arms. I had it aligned, but the caster is too little in the front end. It is supposed to between 7.1 and 8.1 degrees, but it cannot be adjusted past 5.2 degrees. How will this affect the steering? My guess is that it will make it turn in faster. Yes/no? Thoughts please . . .Thanks! |
bostongrun
It will turn faster but will be less stable and might require a lot steering to keep it straight
| Tags |
| alignment , caster |
