Dangers of missing battery clamp?
My E36 318is needed a new battery yesterday. I went to Autozone to have it tested, and confirmed that it was the battery. I figured I might as well let the guy swap my old one and get my core-refund back while I was there.
In the process of changing my battery, the Autozone guy snapped my hold-down bolt. So my stock hold down is no longer useable. He also pulled my vent tube out of wherever it was originally located when he pulled the battery out. I can't seem to properly relocate the vent tube, it seems to be "binding up" when I shove it back into that hole in the frame.
This brings me to my 2 questions...
  • What are the dangers/drawbacks to putting a battery in the truck without the hold down clamp attached?
  • Where does the stock vent tube exit?? How can I re-route the stock vent tube so that it vents properly again?
Thanks in advance!
Matt
Old 11-03-2007, 08:38 AM
A moving battery is always bad news. Stresses will be put on the casing and also on the terminals if the thing can shift around.
I was unable to find the vent tube in my 320 - I fitted an Optima - it's totally sealed - but I'm afraid that does not help you.
Old 11-04-2007, 01:27 AM
Jeron's Avatar
You should fix the battery hold down. The vent tube you can survive without. I don't know how to route it. I would start with finding where it exits and work my way backward.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 11-05-2007, 06:57 AM
Be a little careful - if your battery leaks, it will run into your spare wheel well. Paint will etch off and you'll get a nice little rust surprise next time you change your wheel.
Ask me how I know........
Old 01-08-2008, 04:24 PM
The Man
Send a message via AIM to whosyadadie01
lmao gee i wonder
BMW e36 96 328I convertable
Old 01-09-2008, 09:02 PM
MikeG
missing battery clamp and tube
I have the same issue. I had the original battery replaced at Pep boys which lasted 7 years, unheard of. It was an Energizer. Last year I replaced that one with a Bosch. Set me back $160. They are smaller than the OER that BMW's stocks. Also there were only two made that I found for the Beemer, The Bosch and The Interstae. Anyway the Pep Boys don't really give a damn about rerouting the vent tube or clamping down the battery. I had to do the clamping at home myself on the right (neg terminal side) and ised a piece of wood as a shim on the positive side. It worked well. The vent tube was impossible to find and I still don't know where the damn thing is. My question is:does anyone know where to connect the hose? Is there a clamp made to hold the left (pos( side down so I down need the wood block shim? Thanks.
Old 05-11-2011, 09:21 AM
