bostongrun
How does the fuel consumption gauge work?
Is the fuel consumption gauge really just a vacume gauge.
Low vacume = high consumption
High vacume = low consumption
Is that all their is to it?
Old 07-27-2011, 08:46 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
It is not a vacuum gauge. It's electric.
It works off data coming from the injector pulsing and also the speed of the vehicle. Using this data, the OBC can calculate how much fuel is being used.
Old 07-29-2011, 08:58 AM
bostongrun
Thanks Jared,
Someone else on this board said thats how it worked. It kind of made sense but I didnt really think it was that simple.
Old 07-29-2011, 09:21 PM
A930Rocket's Avatar
My speedo works, but my MPG gauge doesn't.
I've read the problem might be in the circuit board/instrument cluster.
Old 07-31-2011, 09:29 AM
Unhappy Electric NOT Vacuum?
So if it is electric not vacuum, i wonder why my mpg gauge pulses when driving along, around 2k - 2.5 k around 30mph and even more so when going up hill easy?
i have 97 BMW 318i auto with M43 engine
Old 08-02-2011, 09:41 PM
It gets its signal from several sources, none of which are vacuum. The electrical schematics show connections to the ECM, speedo, and service indicator board (SI on E-30 only).
There is very little use of vacuum to control the engine functions other than idle, crancase vent (re-introducing crankcase gasses and unburnt fuel back to the intake to be burned), and fuel pressure regulator.
Does it jump back and forth when the tank is full? Could be gas sloshing around in the tank, also the ecm may be sending more fuel and air to the engine due to changing load conditions which would directly effect consumption.
74 911 targa blk on blk, Carrera fend., tires & whls. gone, missed
85 325e bought new, totaled after 20 years & 465K miles, trouble free service.
01 Ford Ranger 4dr stpsd 4wd. I drive,here
88 325i convert. only 98k miles,gone, sold
93 325i.here, 98 Z-3 roadster. gone, 08 128 cabro gone
Old 08-03-2011, 01:27 PM
