-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   93 E36 Speedometer not working correctly (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/625345-93-e36-speedometer-not-working-correctly.html)
lspeters 08-18-2011 08:28 AM
Hello!
My 93 325IS speedometer is sticking! It goes up in chunks until it hits about 40 MPH, then it stops...a little tap on the dashboard and it moves up a little then stops again. My 16 year old is driving it now so he kinda needs to know how fast he is going!
Thanks for the input!
LP
coolbear1 08-19-2011 08:56 PM
sounds like a loose or dirty plug behind the instrument cluster, it is possible to remove the cluster without removing the steering wheel, but it can be a little tricky.
There are, I think three, plugs on the back, been a while since I had mine out.
If you take it out, replace the bulbs while out. it is easy and the are fairly cheep.
Frajo 08-20-2011 01:36 PM
My 88 325is has the same problem. I removed the spedometer from the cluster and found the circuitry behind the face is corroded.
coolbear1 08-21-2011 06:16 PM
That is common on e30, the e36 cluster is sealed though, no easy access to circuit boards like the one on your 88. I had a hell of a time with my 88 cluster, had it out so many times I could almost do it while driving.
