jbbeema (guest)
Guest
Posts: n/a
i have exactally same problem as bummedbmer, no 1st or 2nd in my auto 325ci.. whats wrong?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Transmission Removal
Old 12-18-2011, 11:13 PM
Author of "101 Projects"
Wayne 962's Avatar
Hi guys. Loud clunks on automatic transmissions are often a sign of low transmission fluid. Have you checked the fluid lately? It's not terribly easy to do, but it may solve your problem. I have an article on this here: http://www.pelicanparts.com/bmw/techarticles/E36-Tranny_Fluid_Auto/E36-Tranny_Fluid_Auto.htm
Other than that, I would suggest you have someone with a code reader take a look at it to see if there are any fault codes that are being put out by the unit.
- Wayne
