 instrument cluster problems whats happening to my 325is? lately the instruments and working fine and then they drop to the bottom and then maybe they will start working again in a few minutes or seconds, everything quits  at the same time, Any help would be great |
 sorry  I forgot to tell its a 1994 325is  thanks |
 Most obvious thing on something like this is loose wiring.  If the entire cluster goes out, a major ground?  Intermittent electrical problems are devil spawn. From experience I know the car will run with the entire cluster out of the car - With the multiple connectors on your dash I just don't know of any one thing that would make everything quit. Henry |
 It's probably a ground issue. You should check all the connections and ground points. Older BMWs have this problem pretty often. |
 I've had two M3s and a 325i and have had this problem with all the cars.  It also disables the cruise control when it goes out.  I suspect that it has to do with the fuse block.  I've found that if I start the car and the instruments dont' work, remove fuse 31 and reinsert it, this will correct the problem until it does it again.  This isn't a permanent fix, but will make your instrument cluster workfor the short term. Clear coat peeling is another issue I've had with all my BMWs. |
| All times are GMT -8. The time now is 10:48 PM. |
