LinkBack Thread Tools Rating: Thread Rating: 3 votes, 5.00 average.
instrument cluster problems
whats happening to my 325is? lately the instruments and working fine and then they drop to the bottom and then maybe they will start working again in a few minutes or seconds, everything quits at the same time, Any help would be great
Old 01-02-2012, 04:30 PM
sorry I forgot to tell its a 1994 325is thanks
Old 01-02-2012, 05:16 PM
Most obvious thing on something like this is loose wiring. If the entire cluster goes out, a major ground? Intermittent electrical problems are devil spawn.
From experience I know the car will run with the entire cluster out of the car - With the multiple connectors on your dash I just don't know of any one thing that would make everything quit.
Henry
Old 01-12-2012, 06:42 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
It's probably a ground issue. You should check all the connections and ground points. Older BMWs have this problem pretty often.
Old 01-12-2012, 09:00 AM
HotRod's Avatar
I've had two M3s and a 325i and have had this problem with all the cars. It also disables the cruise control when it goes out. I suspect that it has to do with the fuse block. I've found that if I start the car and the instruments dont' work, remove fuse 31 and reinsert it, this will correct the problem until it does it again. This isn't a permanent fix, but will make your instrument cluster workfor the short term.
Clear coat peeling is another issue I've had with all my BMWs.
Old 01-24-2012, 06:14 PM
