Guest
Posts: n/a
Hi I want to properly fuel my motronic 1.0 basic N/A application for adding a supercharger 2 bar range ie -1 to +1. I have the spark control covered. Do you sell a solution for the fueling? we used to call these FMU's or 7th-injector systems.. but if you sell a program for modifying the prom parameters on that Motronic 1.0Basic, I'll take that please... otherwise consider this is presently a mass-flow type but I'm not above changing that if there's nothing simple to accomplish fueling while leaving it in place or bypassing part of the airflow around it making it a sampling type meter
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW DME Motronic ECU Swap / Repair |
There are a few DME upgrades you can make if I recall. Drop our sales department a call at 1-888-280-7799 and they can help figure out what you need.
- Nick |
