CHILO (guest)
Guest
Posts: n/a
I RECENTLY REPLACED COOLER HOSE ON A 325I BMW CAUSE IT WAS LEAKING FROM WHERE IT CONNECTS TO RADIATOR.. BUT IT STILL LEAKS EVEN THOUGH ITS A NEW $55.00 DOLLAR HOSE ...... HELP
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Radiator Replacement
Old 05-06-2013, 05:53 AM
Nick at Pelican Parts's Avatar
Check if the fitting at the radiator is leaking. It could look like a hose leak but be the raditor itself.
- Nick
That happened to my 323i. It kept leaking after the new hose and a few days later the neck cracked off where the hose nipple goes into the radiator. Luckily it happened while I was parking. You probably have a crack at that same spot. DON't neglect it! The cooling system empties out in seconds when that neck lets go.
Old 05-10-2013, 02:40 PM
