debbie (guest)
Guest
Posts: n/a
Hello,
I had my mechanic replace the crankshaft sensor and my check engine light is still on and the car is running rough still. It is a 03 325 I any suggestions
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Camshaft Position Sensor Replacement
Old 05-08-2013, 05:36 AM
Nick at Pelican Parts's Avatar
Is the fault code pointing to the crankshaft sensor? Why did you replace it? Address the fault code currently stored. Check the engine for a misfire, this is a good starting point.
- Nick
