Delta (guest)
Guest
Posts: n/a
Have 1987 325ic was driving today & car just shut down will not start, needs codes, had problems last summer was able to restart, fuel pump? Sensor? Could be alot of things
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Camshaft Position Sensor Replacement
Old 05-08-2013, 05:28 AM
Nick at Pelican Parts's Avatar
You're right, it could be a lot of things. Start by checking the DME for fault codes. Once done, you will have to see what is missing, preventing the engine from starting. Check fuel injector pulse, spark and fuel pressure.
- Nick
