-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   1997 328i. The check engine light is on, and the code says crank position sensor. (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/749187-1997-328i-check-engine-light-code-says-crank-position-sensor.html)
PJwood (guest) 05-10-2013 05:26 AM
Hi, I have a 1997 328i. The check engine light is on, and the code says crank position sensor. I bought one from Pelican and went to change it, and there is not one there. The hole for it and its mounting bolt is there, but no sensor. Did this car not come with one?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Crankshaft Position Sensor Replacement
Nick at Pelican Parts 05-10-2013 05:26 AM
Check to see if your model has the crankshaft sensor mounted near the flywheel of the engine. Check the left side of the engine, near starter.
- Nick
