Jonathan (guest)
Guest
Posts: n/a
Do the rear brakes have some connection to the parking brake? Is replacing the rear brakes as straightforward as the front brakes?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing BMW Brake Pads
Old 05-14-2013, 04:27 AM
Nick at Pelican Parts's Avatar
The rear brakes are similar to the front. The parking brake is built into the rear brake system and uses the inside of the rear brake rotor as the parking brake drum. You will have to adjust the parking brake when replacing the rear brake rotors.
- Nick
