Mr. T (guest)
Guest
Posts: n/a
When removing the pilot bearing I used what I thought was a odd idea but worked like a charm. pack bread in behind the bearing, keep backing bread in with a large bolt and hammer. As you pack in the breadkeep adding more in the hole the bearing will come out. then you can simply remove the bread out from hole when the bearings out. It sounds odd but really works if you dont have the right tool.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Clutch Replacement
Old 05-21-2013, 06:37 AM
Nick at Pelican Parts's Avatar
That's anew one for me. Thanks for the tip and feedback.
- Nick
