Guest
Posts: n/a
I just replaced my clutch flyweel, and all my tranmission bushings and washers using your diy. I put the car back together, and my asc light is on, and I have a code for the crankshaft postition sensor. COuld this be becuse I was turning the dirveshaft to get to the bolts? DId I damage the engine any or will the sensor fix the issue? THanks. I have not tried to bleed the system, and I thnk that may be the problem with the asc.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Clutch Replacement |
The sensor does mount in the crankcase and read the tone ring on the flywheel. It may have been damaged. I would remove and inspect it.
- Nick |
