a 1991 325i,i noticed that the tempareture pointer guage is on red when i turn on the ignition without starting the car,,, i did replace the coolant sensor but no change
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3-Series E36 Cooling System Flush |
If the engine starts, runs, and does not overheat, you could have a short in the wiring harness. Check your DME for fault codes using a BMW scan tool. There would be a code stored if a short is present.
- Nick |
| All times are GMT -8. The time now is 11:34 AM. |
