seemelaugh (guest)
Guest
Posts: n/a
a 1991 325i,i noticed that the tempareture pointer guage is on red when i turn on the ignition without starting the car,,, i did replace the coolant sensor but no change
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3-Series E36 Cooling System Flush
Old 05-25-2013, 09:34 AM
Nick at Pelican Parts's Avatar
If the engine starts, runs, and does not overheat, you could have a short in the wiring harness. Check your DME for fault codes using a BMW scan tool. There would be a code stored if a short is present.
- Nick
