Ty (guest)
Guest
Posts: n/a
I've gotten to the point where I need to remove the control arm bolt from the lower strut assembly but I cant get the control arm joint off of the bottom of the strut housing. I've used a center punch and hammer, a tunning fork type fork set, and have simply punded on it with a mallet. I've used a floor jack to compress the strut allowing for the control arm to fall away, using all of the above tools. I can't get the control arm bolt out of the strut housing. Do you have any suggestions that might work. Thanks
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your E30 Front Shocks and Springs
Old 05-28-2013, 10:28 AM
Nick at Pelican Parts's Avatar
Most professional mechanics simply give a good whack with a 5 to 10 lbs small sledge hammer right on the knuckle mount of the strut. Wear eye protection as small bits of metal can chip off and go flying. Brass hammers work best. A mallet with a soft coating will just bounce off.
- Nick
