LinkBack | Thread Tools |
Guest
Posts: n/a
Is removing and reinstalling the CV joint on the front strut 325 iX 4wd the same as the rear cv joint instructions? Will I have to do grease repacking if I remove the CV joint in the front just to replace shocks?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your E30 Front Shocks and Springs |
The procedures are similar but you do have the ability to twist the hub out of the way a little since it pivots for steering. If the boot is not broken and grease has not escaped you do not have to repack it. You may want to repack it just to get longer life out of your CV joint unless you plan and replacing it with and entire shaft assembly in the future.
- Nick |
