Guest
Posts: n/a
i have a 325is coupe E36. i changed the rear shocks and springs but the rear is still lowered. what can i do to raise the rear of the car?. i was told that can use the 5series rear springs but since you are an expect, i will need your thoughts on that.
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Replacing your 3-Series E30 Rear Springs and Shocks |
A stiffer rate spring or a longer spring will raise the car.
- Nick |
