J.M.D (guest)
Guest
Posts: n/a
Hi i have a E36 1995 325ic. Some times the car has the pull/torque when accelerated but sometimes not. Is it because the O2 Sensor is damaged ? Should i replace it ?
Or is it completely due to a different issue ?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW 3 Series (E36) Oxygen Sensor Replacement
Old 05-31-2013, 04:12 AM
Nick at Pelican Parts's Avatar
A faulty o2 sensor would usually set a fault code and illuminate the check engine light.
I would inspect your fuel delivery system. Check fuel pressure, volume and quality.
- Nick
