ARC (guest)
Guest
Posts: n/a
Hello,
My front passenger window has detached from the arms that raise the window. I understand that the end parts of the arms slide in the window guides. I'm just not sure how best to put them back into the guides. Especially the one closer to the front of the door. As it is hidden more so by the metal of the door then the rear one.
I'm thinking, I can take those pieces off the end the parts that slide back and fourth in the guides off the arms, and sliding them into the guides. Then connecting them back to the arms.
Is this feasible?
Good write up, up there, btw
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-15-2013, 06:37 AM
Nick at Pelican Parts's Avatar
I don't think you can remove those guides, I think they are riveted on. You are going to have to unbolt the regulator and while in the door position the guides correctly then secure the regulator to the door.
- Nick
