od (guest)
Guest
Posts: n/a
My comment is about bmw 525i 1989 after overhitting it refuse to start smelling like burning something since then didnot even swing the is click sound when i attempt to start I thought is a bettery flat but I suspect the is no combussion and i saw smoke came from the exhost linked to the block that was strainge pls help out on this one
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-15-2013, 06:31 AM
Nick at Pelican Parts's Avatar
If the engine does not crank when you turn the key then you probably have a bad starter or ignitions switch. If it does crank then you probably have a jumped timing chain from over revving it.
- Nick
