Emil P (guest)
Guest
Posts: n/a
Did the valve cover gasket the 2nd time, it still leaks toward the lower rear of cover, gasket & cylinder head. Applied RTV at recommended spots. Replaced rubber washers on all nuts, clean surfaces & torque valve cover nuts at specs. Any suggestions to stop the leak?
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-15-2013, 06:19 AM
Nick at Pelican Parts's Avatar
You can go a little tighter on the mounting nuts but you have to clean and isolate the leak. Is there a crack in the metal there? Although it's not recommended you can put RTV there around the whole area
- Nick
