KrGowri (guest)
Guest
Posts: n/a
After replacing the gasket, I am getting P0171/P0174 codes, but I do not have any vacuum leaks. What could cause this?
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-15-2013, 06:25 AM
Nick at Pelican Parts's Avatar
Low fuel pressure or a bad MAF can also cause lean codes. Do you have an exhaust leak because that can also cause false lean codes
- Nick
