Okey. I have ONE question. How did i end up with this in the photo Bearing and flex-disc is replaced but i just wonder. As i see it the bracket is supposed to line up with the screw-threads, right?
This post was auto-generated based upon a question asked on our tech article page here:
Old 07-16-2013, 12:44 PM
Nick at Pelican Parts's Avatar
Is the drive-shaft in backwards? The center bearing mount is lining up with the u-joint on the driveshaft and that can't be right
- Nick
Hey Nick. You know what, the shaft has been buging me for a time now but today i figured out the problem. For instance The original bearing-bracket has another design and if im right the details of the new one probably got other supported carspecifications, at the moment i don't quite remember these specs. The ride is a -92 325i coupé Automatic originally but back in time changed over to a manual.
By looking at my normal parts-shop there's 2 different kinds of bearings. One of them points from 12/94 and the other one from 11/90 wherea's even this one supports both auto. plus manual.
Pretty sure i ended up with the wrong one =)
Old 07-16-2013, 01:51 PM
