-   101 Projects Discussion Forum: BMW 3-Series (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/)
-   -   Should I resurface the rotors? (http://forums.pelicanparts.com/101-projects-discussion-forum-bmw-3-series/761370-should-i-resurface-rotors.html)
Absolute beginner! (guest) 07-16-2013 01:52 PM
Great description - didn't know about having to re-surface the rotors. Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Nick at Pelican Parts 07-16-2013 01:52 PM
If you are not replacing the rotors you should resurface them to prevent the brakes from squeaking while braking
- Nick
howard freeman 07-17-2013 02:38 PM
You better mic the rotors,& check the runout before machining. They could to thin, which they usually are. Its far better & less expensive to just replace them. Use the Zimmerman coated rotors.
