Guest
Posts: n/a
Great description - didn't know about having to re-surface the rotors. Thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
If you are not replacing the rotors you should resurface them to prevent the brakes from squeaking while braking
- Nick |
You better mic the rotors,& check the runout before machining. They could to thin, which they usually are. Its far better & less expensive to just replace them. Use the Zimmerman coated rotors.
Howard Freeman 80 911 SC & 74 914 1.8 79 930 & 83 SC coupe,03 996 TT,02 996 C4 03 X/5 3.0. 370,186 miles now Sons daily driver 10 X5 3.0I 224,515 miles |
