Guest
Posts: n/a
There are quite a few connectors that are the same. The car dose t want to idle right. If you give it the gas and hold it around 1000 rpms it smooths out. Any ideas?
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Sounds like you might have a vacuum leak affecting your idle speed. Try spraying carb spray around the intake and see if you spray in a certain area and the rpm smooths out you have found your leak
- Nick |
