JHS (guest)
Guest
Posts: n/a
86'528e timing belt replacement.i am well along on this everthing re the belt is back.problem is the tensioner-the spring is in place and center bolt installed but not tight. is there a way to get the tensioner to the right so that the right mounting hole lines up with the slot.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-11-2013, 11:01 PM
Try using a pry bar to lever on the tensioner. These belts are tight and this may help you get the other mounting bolt lined up in the slot.
- Kerry
