LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
86'528e timing belt replacement.i am well along on this everthing re the belt is back.problem is the tensioner-the spring is in place and center bolt installed but not tight. is there a way to get the tensioner to the right so that the right mounting hole lines up with the slot.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Try using a pry bar to lever on the tensioner. These belts are tight and this may help you get the other mounting bolt lined up in the slot.
- Kerry |
