jc (guest)
Guest
Posts: n/a
I have had same problem with no hot air. Will try and replace heater valve too. Why does expansion tank fill with only 2 gallons of coolant? Doesn't the coolant capacity take more than that. I have an '04 BMW 745Li.
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-27-2013, 07:20 PM
Unplug the heater valve and it should default to full open and therefore full heat. Sounds like you may have to bleed the cooling system after refilling
- Kerry
