Chris H (guest)
Guest
Posts: n/a
I will be installing re-grind cams in my '96 M3 in the near future. I have two questions. 1 When removing the stock cams, will the S52 cam profiles allow free play on cylinders 2-6 as described in the writeup, or will I need to use the alternate method and loosen those caps 1/4 turn at a time? 2When installing the new modified cams, is there anything special I will need to do since the profiles will be different?
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-06-2013, 05:32 AM
Nick at Pelican Parts's Avatar
Loosen them 1/4 turn at a time. You are going to have to check the valve lash and also look for interference issues with the pistons and valves.
- Nick
