Guest
Posts: n/a
Two questions. First I have a 1990 bmw 325i e30 and can't seem to locate the camshaft positioning sensor. Second, my car seems to no longer get fuel once the engine is warm, I have replaced the fuel filter and fuel pump relay, it idles much better now however still cuts off putters of as if lacking gas. Any ideas? I believe my actual fuel pump is still good.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
The should not have a cam sensor, there is a distributor on the front of the motor. I would install a fuel pressure gauge a measure the fuel pressure and then check for fuel volume.
- Nick |
