diva_3181377 (guest)
Guest
Posts: n/a
How difficult is to replace the selector shaft seal? Part # 24101218852 item 2 in http://www.realoem.com/bmw/showparts.do?model=CH93&mospid=48092&btnr=24_0801&hg=24&fg=15. It is leaking there. I already bought it from pelicanparts.com. Can i do it without dropping transmission or transmission pan? Any DIY?
This post was auto-generated based upon a question asked on our tech article page here:
Old 09-06-2013, 01:15 PM
Nick at Pelican Parts's Avatar
You can replace the seal without removing the trans, you will have to drop the trans cross member to gain access but it can be done, the seal is very hard to get over the shaft without damaging it, so be careful and take your time, use a little grease on the inside of the seal to make it easier.
- Nick
What is a transmission cross member? Is the one where the bushings are? Also is there a tool pelican sells to remove it easily (rather than prying it out?) I found the BMW have some tools for this purpose.
Thanks..
Old 09-06-2013, 02:25 PM
