Guest
Posts: n/a
How much force should it take to put a CV Shaft back in on the rear of a E36 99 M3. Once side went in ok not too much rubber mallet but the other side just wont go back in easily. Was doing a rear bearing and hub replacement on both sides. Concerned how much pressure or force is really needed or is something else wrong.
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
Use a wire brush to clean all of the rust from the splines and make sure they are not damaged, use so light oil like WD-40 and it should go back together.
- Nick |
