LinkBack | Thread Tools | Rate Thread |
Guest
Posts: n/a
Anyone know or had this problem? I have a 04 330ci e46 3.0 2dr
It's done it for a year and I'm used to it now, but when I put it in drive it takes about 5-8 seconds before it will actually engage and drive forward? It shifts very smooth so I don't think it is the transmission? Should I just leave it? After I've drove it, it's fine and engages straight away, __________________ This post was auto-generated based upon a question asked on our tech article page here: |
Try flushing the fluid and changing the filter. Sounds like the transmission is draining back into the pan and it is not supposed to. Also you may have a bad 1-2 shift solenoid? Any codes?
- Kerry |
