Guest
Posts: n/a
Hey guys, my '87 325is has a driveshaft harmonic damper. I've read conflicting things on the internet about whether or not I need to keep it. Can you share your wisdom? I also think mine may not have been installed correctly based on where it was when I removed it. It was rearward of the tranny output flange. From my reading, it seems it should actually be mounted on the forward engine-side side of the tranny output flange. If I need to keep it, how should it go back on? Thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
If it was on the car from the factory the car needs it for some reason. BMW would not spend money to put useless parts on cars.
- Nick |
