Guest
Posts: n/a
Hi. I have a e36 323i coupe. After going over a damaged road without knowing, after I release the e brake from parking, I drive and it makes squeaking noise like it's not released properly. And then I pull the e brake up a little bit while the car is moving, it makes a *click* noise and stops the squeaking noise.. what do you think is wrong? Thanks
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
The parking brake shoes may have come apart. I would inspect the brakes on the axle of the vehicle that are making noise. Remove the rear rotor to inspect the parking brakes.
- Nick |
