willyb (guest)
Guest
Posts: n/a
OK, found the heater valve right where you said it was . Never doubted you. Cannot get it off the mount. Rubber round bushing on the top slides off easy. bottom rubber mount does not. Should i be removing the metal bracket it is attached to ?
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-21-2013, 04:05 PM
Yes remove the metal bracket the rubber is there to insulate it from vibration
- Kerry
