If the crank sensor is damaged, will it not allow the automatic transmission to shift gears especially fourth it seems to retard the acceleration. Please help
__________________ This post was auto-generated based upon a question asked on our tech article page here: |
No, you will need to check codes in both the DME and the EGS systems to see why you aren't shifting into 4th gear.
- Kerry |
| All times are GMT -8. The time now is 05:03 PM. |
